Sponsored by: Innova
01 expedition sub replacement
Old Jan 27, 2005 | 08:44 PM
DiamondMaxx's Avatar
DiamondMaxx
Question 01 expedition sub replacement
I have an 01 expedition eb with the mach sound system. The rear sub doesn't work and I need to replace it. Should I use an aftermarket one or stock. What aftermarket subs are direct fit? Is it 8 in or 10 in ? 4ohm or 8 ?
Sorry for the newbie questions.
Any info would be appreciated.
Thanks
Old Jan 27, 2005 | 09:08 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Stick around someone will be by shortly to answer your question.
We are pleased you have chosen the best source for Fords!
Enjoy FTE …..See you on the boards.
Old Jan 28, 2005 | 09:23 PM
dafunkdawg's Avatar
dafunkdawg
8" 4 ohm.i haveput kicker and fosgate speakers in these and they sound fine.there is usually a bolt through the back of the enclosure into the magnet holding the speaker in so be ready
Old Jan 29, 2005 | 09:53 AM
DiamondMaxx
Thanks for the info.
Old Jan 30, 2005 | 04:11 PM
DiamondMaxx
Still No Sub
I replaced the factory sub with a JL 8W0-4, but it still didn't work. Seems there's no power going to it. No power going in to the amp next to it either. I checked the fuses in the box under the dash. All good. Anyone have any suggestions? The radio and cd changer work. Just no sub.
Thanks
Old Jan 30, 2005 | 09:11 PM
DiamondMaxx
Does the factory amp have a remote turn on that plugs into the receiver? Where does the power for the amp come from? Anyone know the wiring?
SneakyF350
6.7L Power Stroke Diesel
Nov 23, 2010 02:55 PM
Crownline04
2004 - 2008 F150
Jun 8, 2008 10:16 AM
JB7
Jul 14, 2004 03:01 PM
erik227
May 3, 2004 08:37 AM
