No Spark
Old Jun 26, 2002 | 07:04 AM
Gates's Avatar
Gates
No Spark
Well here is the problem, on my 91 F150 302 4x4, four cylinders are not firing. I get a very weak spark if any on cylinders. The firing order is 15426378, cylinders 2637 are the ones that are not firing.
I know they are getting fuel, wet plugs, gas in oil (had to change oil yesterday). I measured voltage in the TFI harness and it is getting voltage, and if the TFI isn't working it wouldn't be getting fuel. I am thinking that it is the PIP sensor.
Any ideas or suggestions on what to check?
Thanks
Old Jun 26, 2002 | 01:00 PM
Franklin2's Avatar
Franklin2
No Spark
It is funny that the cylinders that are not firing are in sequence with the firing order. I would check the dist cap area too. What if the dist shaft was bent, or maybe there is a carbon track under the cap, shorting out that area of the dist cap. The pickup inside sounds like a good candidate too.
Old Jun 26, 2002 | 02:18 PM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
No Spark
ford_medic
32
Mar 10, 2018 09:04 AM
CWPottenger
Jul 28, 2012 03:33 PM
Jrod13
15
Aug 3, 2007 06:40 AM
Cliff Cerce
Mar 6, 2005 03:36 PM
wndrhmr
May 4, 2004 09:07 PM
