More Power!!!
Old Jan 27, 2005 | 05:49 PM
1993_f150's Avatar
1993_f150
More Power!!!
I have a 93 F150 Xlt 4X4 with a 302 V8 Engine. I was wondering what the best thing to do was to get more power, but with a limited amount of money.
Truck doesnt seem to have enough power. Thanks for all the help
Derek
Old Jan 27, 2005 | 09:11 PM
daerhldgs2's Avatar
daerhldgs2
gears are quick and easy but can be expensive. What type of tranny are you running?
The usual things such as a more efficient air filter, headers,good exhaust system,better heads,cam etc. it all costs money!Cheapest way is probably a 351W.
Old Jan 27, 2005 | 10:40 PM
Matt95L's Avatar
Matt95L
Whats your budget?
Old Jan 28, 2005 | 09:10 AM
Kemicalburns's Avatar
Kemicalburns
Gears will increase towing and passing capabilites but kill some of your top end. nice thing about it though is your motor stays reliable. anytime you start into the motor it may decrease the life of that motor. Headers and a good flowing single exhaust would help alot to and not decrease reliability. also edelbrocks truck efi intake would be a nice addition as well.
if you somewhat mechanical then another option is a 5.8 swap. Ive done it along with many others and its pretty easy and is a great increase for the money.
good luck
Old Feb 3, 2005 | 03:53 PM
1993_f150's Avatar
1993_f150
iam running a automatic transmission
Old Feb 3, 2005 | 03:58 PM
cek181's Avatar
cek181
keep the 302, have a drivetrain shop put in 4.10 gears- and while your at it put in some kind of low end locker on the back. you'll be real happy with the performance. always helps to have it fully tuned up with good filters and fluids, a freer flowing exhaust and a high capacity intake. ive had a 91 and a 95 302- both were pretty gutless, but there is lots of potential there if you gear it lower. good luck
Old Feb 3, 2005 | 04:17 PM
Kemicalburns
but if he puts in gears you must do both front and rear. that gets expensive.
Old Feb 6, 2005 | 12:57 AM
94F150-408's Avatar
94F150-408
I have to agree with Kemicalburns, save your greenbacks up for a 351...theres no replacement for displacement!
