2.3 turbo fuel system/pressure
Old 02-04-2005, 12:49 AM
RacinNdrummin's Avatar
RacinNdrummin
RacinNdrummin is offline
Do Any of you who have done the 2.3 turbo swap into your ranger know what controls the fuel pressure on the 2.3 turbo engine? Does it use an FMU or is pretty much all the flow controlled through the injectors by the computer? Also if done on an 85' earlier, what has to be done for the fuel return line to the tank?
Old 02-05-2005, 10:28 AM
1mean02HD's Avatar
1mean02HD
1mean02HD is offline
The fuel pressure regualtor on the fuel rail controls the fuel pressure. There is a vaccuum line connected to it and is not adjustable from the factory. BUT, an aftermarket adjustable regulator for a 5.0L Mustang will work on the 4 bangers. Hope this helps you out.
Old 02-05-2005, 11:31 AM
IndySilverAnny's Avatar
IndySilverAnny
IndySilverAnny is offline
one site.
turboford.org.
All the 2.3 turbo info. you could ever need.
Lots have done the ranger 2.3 turbo swap.
Red23
12-16-2013 03:57 PM
JD717
4 Cylinder Engines
02-01-2006 04:38 PM
deltaranger
4 Cylinder Engines
08-16-2004 01:10 AM
Quick Reply: 2.3 turbo fuel system/pressure
