Wrong Intake Gasket?
Old Jan 25, 2005 | 10:15 PM
TXDod65's Avatar
TXDod65
Question Wrong Intake Gasket?
I went to put my new intake gasket on my '68 360 and found that the intake gasket doesn't have a port for the exhaust to match the intake. The package for the gasket lists the gasket for 352, 390 and others (not 360). Is it wrong for my 360? I'm guessing it is, but don't know why - thought some of you gurus out there could explain.
Old Jan 25, 2005 | 11:34 PM
jstandle's Avatar
jstandle
Should be correct, the FE's share the same design. FT's I think are a little different though.
Old Jan 26, 2005 | 10:23 AM
bertha66's Avatar
bertha66
Did you turn it end for end? Just a thought.
Old Jan 26, 2005 | 10:34 AM
TXDod65's Avatar
TXDod65
Yeah - it's strange. Everything lines up, but there is no passage for the exhaust port (should be one on each side?).
Old Jan 26, 2005 | 03:09 PM
KCampbell's Avatar
KCampbell
I had the impression that some intakes did not have the exhaust cross over port, not in these trucks but perhaps in some of the cars to which they were fitted? Definitely sounds like the wrong gasket.
Kevin
Old Jan 27, 2005 | 09:16 AM
TXDod65's Avatar
TXDod65
My parts guy tells me that the performance gaskets typically don't have the exhaust port. He said that the exhaust crossover is there to help warm the intake (especially useful in cold weather environments). He advised that as long as the gasket covered the exhaust port completely, it would be okay. He suggested that if I wanted the "warming" feature, I could cut a hole in the gasket.
The reason I'm not going with the standard intake gasket set (OEM style) is that I was told that the Aluminum intake isn't stiff enough to seat the hard gasket, therefore requiring the softer high-performance style gasket.
Martin Torres
Oct 22, 2016 07:35 PM
Martin Torres
Sep 23, 2016 12:08 AM
tbruz
Jun 3, 2016 07:14 PM
usuallybowtie
16
Jul 13, 2015 08:29 PM
scottlane
Exhaust Systems
Jun 12, 2006 09:47 AM
