Sponsored by: Real Truck
16" Wheels
Old Jan 26, 2005 | 12:26 AM
jbsilva's Avatar
jbsilva
16" Wheels
Does anyone know if 16" wheels will fit on the 2005 SD 4wd? I want to know before I buy.
Old Jan 26, 2005 | 05:51 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE. Stick around someone will be by shortly...to answer your question.
We are pleased you have chosen the best source for Fords!
See you on the boards.
Enjoy FTE …..
...MOVED>>>>
Old Jan 26, 2005 | 07:22 AM
mizzitch's Avatar
mizzitch
I doubt that any 16" wheel will fit the 05's since the smallest rim from the factory is a 17, due to the increase in rotor size for 05. Plus, any 16's out there probably have the wrong backspacing for an 05.
Old Jan 26, 2005 | 08:00 AM
DJR 17's Avatar
DJR 17
you can go to your local tire dealer and try a rim out to see...
Old Jan 26, 2005 | 04:39 PM
jello's Avatar
jello
I think ford changed the bolt pattern spacing again for 2005
