351M/400 inter-changeable?
Old Jan 25, 2005 | 09:45 PM
weverette1's Avatar
weverette1
What engines can be used in place of the 351m400?
My truck is a 79
Old Jan 25, 2005 | 09:49 PM
zwinstead's Avatar
zwinstead
Any as long as you change enough junk
The 315M and 400 are two different engines
Well a 351M or a 400 are the only direct bolt in's. The 460/429 share the same bellhousing, but accessories and mounts are different
Old Jan 25, 2005 | 09:56 PM
weverette1's Avatar
weverette1
So, how do I determine which engine is in the truck now?
Old Jan 25, 2005 | 10:00 PM
zwinstead's Avatar
zwinstead
If there is a sticker under the hood it will usually say Engine Family 351M/400 and then after that or next to that it will say Eng CID 351M or 400 depending on what you have CID means Cubic Inch Displacement If the sticker is not there I dont know of another way to tell if its a 351M or a 400 besides tearing a head off and measuring the stroke
Old Jan 25, 2005 | 10:02 PM
weverette1's Avatar
weverette1
No sticker.
Changed valve covers.
How about #'s on the block?
Old Jan 25, 2005 | 10:09 PM
zwinstead's Avatar
zwinstead
same block between the two, the only diff is the crank and pistons anyone else got any ideas??
Old Jan 25, 2005 | 10:27 PM
Torque1st's Avatar
Torque1st
Posting Legend
Welcome to FTE!
There is no way to find out except to measure the stoke. If the engine is original in the truck the VIN code will list the engine size. Check out the Read First: FAQ thread at the top of this forum for VIN number information.
Old Jan 26, 2005 | 09:22 AM
460429_freak's Avatar
460429_freak
what are you asking which motor you have
measure the distance between the top two transmission bolt a 302 351w are closer than the 351m/400 460 429
Old Jan 27, 2005 | 09:01 PM
FordTruckTechNut's Avatar
FordTruckTechNut
on a 351 M the thermostat housing is seperate from the intake manifold bolts vertical pointing towards the top tank of the radiator at an angle, the winsors comes out pointing straight up bolts horizontal. but the only way to visually tell if it is a 400 or 351m is crack the heads off that baby. Also heard that the 400 harmonic balancer is thicker. don't know if it is true.
Old Jan 28, 2005 | 07:01 PM
kc5hwb's Avatar
kc5hwb
Harmonic balancer is the same. I just changed my 351m over to a 400 and everything was the same, except the pistons and crank. That is really the only way to know.
Old Jan 28, 2005 | 07:33 PM
MBDiagMan's Avatar
MBDiagMan
No, the harmonic balancer is not the same between the 400 and 351M. The 351M will fit onto a 400 crank but it is not the same balancer. For long engine life, you should have the correct balancer for the engine.
The only difference between 351M and 400 are crankshaft, pistons and harmonic balancer.
I have no idea how you would tell which one it is without pumping the volume on a cylinder.
Good luck,
Doc
Old Jan 28, 2005 | 08:00 PM
kc5hwb's Avatar
kc5hwb
Well, you ask around and you will get different answers to that. Some mechanics tell me it is the same...some tell me it is not. You say it is different, but several others in this forum say it is not. So who knows, really....
I guess the machine shop could have changed mine without my knowing. It looks VERY similiar, though
Old Jan 28, 2005 | 09:56 PM
1976 drag's Avatar
1976 drag
if the only difference is the stroke why not just put #1 on tdc and pull the spark plug off and then put a little rod down and mark where it is and then do the same to #4....mark the difference and there ya go?
RangerHaywood
15
Jul 5, 2010 10:14 PM
cruz76
Mar 26, 2006 05:40 PM
theonlybull
Jan 13, 2003 08:04 PM
Sunfire_Stomper
Sep 4, 2002 07:03 AM
Nathan
13
Apr 18, 2001 02:10 AM
