Relocating gas tank
Old Jan 25, 2005 | 07:34 PM
mla's Avatar
mla
Relocating gas tank
I'm working on a 68 100 with a 390, and the gas tank behind the seat is shot....
need to replace it but would rather have it outside the cab, any ideas???
Old Jan 25, 2005 | 09:24 PM
stevef100s's Avatar
stevef100s
This is one of the most talked about subject on these trucks. It would help you to do a search here, since so many options have been covered.
Old Jan 26, 2005 | 11:08 AM
rebocardo's Avatar
rebocardo
$499 gas tank/toolbox combo from northerntools.com, DOT approved for gas.
Old Jan 26, 2005 | 02:12 PM
thesprocket26's Avatar
thesprocket26
Check my gallery on "Gastank Relocation"
Old Jan 26, 2005 | 05:25 PM
jwtimme's Avatar
jwtimme
I put a 64-67 mustang gastank under the bed of my 72. It was a pretty clean instulation. I used 1x2 tubing instead of the 1x1 used in the tech artical on this web sight. I got a filler neck from a local boating supply store. Pictures are in my gallery of the tank in the truck, but I think the bed is off at the time.
Old Jan 27, 2005 | 03:28 PM
floss67's Avatar
floss67
Jwtimmie,
Saw your pics on the gas tank. Looks great. I'm in the process of doing the same thing. Any other specifics I need to know other than the 64-67 Mustang tank? The only tech article I found on this was for a "pre-67" and its not quite the same dimensions.
Old Jan 27, 2005 | 04:16 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
We are pleased you have chosen the best source for Fords!
Enjoy FTE …..
See you on the boards.
