Im having a difficult time trying to figure out why my 360 isnt making the power it should be making would it help if i rebuilt the carb also i was thinking of some other ways to get some more power out of her but im not sure what would be the easiest way now im not looking for loads more power just enough do get some heavy duty work done now and then also would it help to get a bigger carb all together ive heard that a few times
alright thanx for the input i want to put a 390 into it that would be nice do you guys have anyopinions on this engine and if there are anyother engines i should look into i dont want to big cause i need some kinda gas mileage so thanx
Check your timing, do a complete tune-up, even get a scope check . Make double sure everything is right before you spend money on a bigger carb . If a 360 is tuned right it is an good motor, not quite as strong as a 390 but way stronger than my 302.
