Bronco II Ford Bronco II
brake problem
Old Jan 25, 2005 | 05:14 PM
steelerfantomo's Avatar
steelerfantomo
Question brake problem
The right rear cylinder was leaking bad, so I replaced it. When I added new cylinder and pads, I could not get any fluid to rear of truck. Master cylinder is pumping fine. I get fluid up to sensor mounted on the frame below engine. I removed sensor and blew air thru it. I also blew out line all the way back. I still cannot get any fluid to the rear of truck. Front brakes are working fine even with rear out. Am I missing something? Is my master cylinder shot now? It was working fine until the leak started. Please help....
therealulysses
Aug 26, 2012 07:08 PM
|WYG|SS
1978 - 1996 Big Bronco
Jun 13, 2011 10:08 PM
blee1ash
Mar 8, 2011 11:55 AM
bryan_johnson
Mar 6, 2005 07:49 PM
ham4ever
Nov 9, 2004 02:15 PM
