egr bad
Old Jan 25, 2005 | 09:19 AM
dmacfordshot04's Avatar
dmacfordshot04
egr bad .replace or not
my 86 f150 351 ho has a bad egr .truck runs fine execpt for little hesitation
on from a complete stop.is it nessasery to to replace it at 60.00 bucks?
Old Jan 25, 2005 | 11:40 AM
688i's Avatar
688i
How do you know it is bad? I was getting the 131 code on mine and fixed it by unscrewing the top, dropping a penny in flat and screwing the top back on. It seems the gap between the probe and sensor wears until the signal is lost. I have a 302 FI so am not positive yours is identical.
Old Jan 25, 2005 | 12:21 PM
fellro86's Avatar
fellro86
Another thing to try before dropping the bucks is to take it off and spray a penetrating oil on the pintle and shaft, and work it. I had one a while back that the pintle was stuck open, and it was about $80 to replace, so I tried soaking it in WD40, and it cleaned all the carbon off, and freed it up, and works fine.
Old Jan 25, 2005 | 01:22 PM
dmacfordshot04
i tried all that &had it checked &it does not hold vac due to a bad diaphragm .
Old Jan 25, 2005 | 01:27 PM
dmacfordshot04
i just want to know if that will cause the hessitation problem ithat i am having before i go replacing it?
Old Jan 25, 2005 | 01:32 PM
fellro86's Avatar
fellro86
ok, a bad diaphragm will cause a vacuum leak, and it unfortuantely does need to be replaced. You could plug the hose temporarily to check and make sure if the hesitation goes away.
Old Jan 25, 2005 | 02:31 PM
dmacfordshot04
will do .i"ll let you know when i go out later on this afternoon . thanks alot
Old Jan 25, 2005 | 04:32 PM
dmacfordshot04
bad news for me . i plugged ithe hose &it still hesitates sometimes .igot the feeling its carb problems . since i see no evidence of vac leaks
Old Jan 25, 2005 | 04:50 PM
fellro86's Avatar
fellro86
check the accelerator pump, it may noe be squirting as it should, that would be where I would check...
Old Jan 25, 2005 | 05:34 PM
dmacfordshot04
i can see both jets squirting gas strong.i plan on replacing carb this spring withan eldebrock ,so i"ll just have to put up with it . thankyou
dullybob
Mar 3, 2013 11:01 AM
THE BLUE HEAP
29
Feb 12, 2010 08:10 PM
dantsg
1997 - 2003 F150
Apr 26, 2009 04:59 PM
brwolfjr
Feb 22, 2009 12:20 PM
