Stroking and poking a 300
Old Jun 14, 2002 | 12:34 AM
shaneFalco's Avatar
shaneFalco
I own an 85 F-150 with a 300 6 and four wheel drive and i was wanting to stroke it and boring. Does any one know the max that these stock blocks can handle?
Shane Armfield
85 F-150
72 Mustang
Old Jun 14, 2002 | 06:14 PM
Syzle's Avatar
Syzle
These engines have a lot of stroke right from the factory. I don't know how much more you could stroke them without having problems. Good luck though
Old Jun 16, 2002 | 09:30 AM
serian's Avatar
serian
The I6-300 comes factory stock with a 4" stroke,
which gives it quite a good amount of torque. I
believe that oversize pistons are available in .030
and .060 over. As I understand it, the cylinder
head can be machined down by .090 as well.
Old Jun 16, 2002 | 11:30 AM
fiend's Avatar
fiend
Can someone explain to me what "stroking" means, and what good it does to machine down the head and shave them and stuff?
Thanks
Old Jun 16, 2002 | 03:34 PM
serian's Avatar
serian
"stroking" an engine involves changing the crankshaft
and piston rods in order to get a larger stroke from
the pistons. More stroke typically yields more torque.
Machining, or "milling" the cylinder head results in
less volume in the combustion chamber. As long as
there is enough valve clearance in the chamber,
altering it so that there is less volume results
in more compression, and likewise more power output
from your engine.
Old Jun 17, 2002 | 07:51 PM
Ford Truck Racer's Avatar
Ford Truck Racer
the crank stroke is the distance of the center on the crank to the center of the rod journal. By stroking it you put a longer distance from center to center which gives your rod more leverage in turning the crank. more leverage computes to equal more torque since its easier to turn.
Old Jun 18, 2002 | 10:39 PM
shaneFalco's Avatar
shaneFalco
So does anyone know of a stoker kit out there for the 300?
Old Jun 18, 2002 | 11:46 PM
mustange70's Avatar
mustange70
Why don't you raise the compressioon to something like 13:1 and build it to run on propane? An engine builder says the 300 I-6 responds very, very well to this.
82' Flareside: zoom zoom doesn't even begin to describe it
2/4 Drop
Soon to have 325hp 351 Clevo
(maybe more,in a 3600lb truck)
Backed by a C6 with a 2000 rpm stall and a 3.50 9 incher
American Racing AR-23 (series 23) wheels
Upgraded interior
Soon to install: Sony Xplod stereo
Old Jun 19, 2002 | 09:25 AM
Ford Truck Racer
I have never seen a stroker kit. But some of the best things you can do is to maybe bore it, raise compression, put a hotter camshaft, good 4 barrel intake and a high flowing header with a 3 inch exhaust out the back.
Old Jun 19, 2002 | 08:57 PM
fiend's Avatar
fiend
Just wondering, but how much would it cost to do stuff like machine the heads?
What kind of stuff would ya'll recommend to beef up a stock EFI 300/6?
Old Jun 20, 2002 | 04:09 PM
Ford Truck Racer
Crane makes a Cam with 260/272 duration and 458/487 lift designed for 1200-5000 rpm at $110. Dynomax has a good header for about $130. All from Jegs. JcWhitney sells an Offenhauser 4-barrel intake manifold for $200. Top it off with an Edelbrock 500 or 600cfm carb and I think you will have a stout little six. If you do some research though I know you can find higher compression pistons. Seen them before just can't remeber where.
Old Jul 6, 2002 | 11:26 PM
aunchman's Avatar
aunchman
I ahve what u are looking for my man.. A realyl strong inline 6, pushing about 300 Hp, very nice comp cam, custom chevy valves, I have about 10,000 on it let me know if u are interested!
Later
Chris
Old Jul 18, 2002 | 07:57 PM
desperado_18_2000's Avatar
desperado_18_2000
Old Jul 21, 2002 | 09:20 PM
larbera76's Avatar
larbera76
technicaly the 300 only has a 3.98" stroke. but yea. it also has a 4" bore. If you wana know all there is to know about the 300, go to www.fordsix.com
cooploops
Jul 17, 2008 01:47 PM
Mikestrucks
Oct 26, 2007 11:41 AM
Shanemh
May 3, 2007 05:35 AM
Shanemh
Jan 15, 2007 08:40 PM
Shane
Mar 8, 2000 09:11 PM
