86 engine swap
Old Jul 18, 2002 | 07:14 PM
LoudPipes66's Avatar
LoudPipes66
86 engine swap
I am currently swapping the engine in my 86 F-150. I am taking the original efi 302 out and putting in a efi 302 out of a 89 E-150. I was told that i will have to change all my sensors on the motor from my 86 to the 89. Can anyone please tell me specifically by name which sensors i will need to change. Also i am taking the pumps and brackets off the 86 motor(which has v-belts) and putting them on the 89 (Which originally had a serpentine belt).I will be using the 86 pumps, brackets and belts on the 89 motor. My question is will this work? I know these questions may be dumb but it has been bothering me all week. Any help will be greatly appreciated.
Old Jul 18, 2002 | 07:57 PM
desperado_18_2000's Avatar
desperado_18_2000
86 engine swap
if you use all the front peices off the 86 and put them on the 89 it will work fine, the crank pully/harmonic balancer will also swap (or should)If the 89 engine uses a split plenum intake like the mustangs i belive you will need the computer/wire harnesses out of the 89 vehicle to go with your engine along with its sensors. this is about it, if i left something out someone will jump in!
HTH!
Old Jul 21, 2002 | 10:49 PM
fordguy4x4's Avatar
fordguy4x4
86 engine swap
I don't know about the sensers. but unless you are after the factory stock look the srpentine belt is better (one adjustment}. If your sure you don't want them I would love to have them for a 351w Ijust got to replace the 300six in my 83f250.
Old Jul 22, 2002 | 08:42 AM
cpettymore7777's Avatar
cpettymore7777
86 engine swap
