Sponsored by: Real Truck
fuse mix-up
Old Jan 25, 2005 | 12:29 AM
fisherg7's Avatar
fisherg7
Question fuse mix-up
Hello folks....new member here. Got a 99 F-250 SuperDuty that i have somehow got the inside fuses all mixed-up. long story but it all started with no high beam headlights. I noticed that the fuse diagram in my 99 F150/F250 manual was different from what was actually in the under-dash box. under dash box only--I was smart enough not to mess with under hood fuses.
anyway i need a good breakdown for which fuse goes in which under-dash slot. also the amperage. also what does each fuse power. Specifically I have no dashboard instrumentation gages working....ie rpm,speedometer,batter voltage, etc. Which fuse handles this?
My truck is a 5.4L gas engine. I think it may be a late or half-year vehicle. I bought is used a year ago.
Old Jan 25, 2005 | 07:22 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Welcome Guy...to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE. Stick around someone will be by shortly...to answer your question.
We are pleased you have chosen the best source for Fords!
See you on the boards.
Enjoy FTE …..
Old Jan 25, 2005 | 11:18 AM
fisherg7's Avatar
fisherg7
Thanks ! glad to be onboard.
Old Jan 25, 2005 | 12:11 PM
Brad99SD's Avatar
Brad99SD
Not possitive on this fisherg, but doesn't the manual tell the location and the current capacity(amps) and what they power. Like I said, I haven't looked for a while but maybe I will look in my manual and check witch fuse is for the instrument panel. hang tight.
Old Jan 25, 2005 | 12:20 PM
Brad99SD's Avatar
Brad99SD
You must have a light duty F-250 manual, not the Super Duty one because mine just says Super Duty. Anyway, maybe if you have an email I could scan in my pages and send them to you since I don't know if you can send attachments on FTE. Let me know.
Old Jan 25, 2005 | 10:50 PM
fisherg7's Avatar
fisherg7
yes, you are right--i have the wrong book. please send me the scanned fuse pages at guy_fisher at hotmail
@ sign omitted otherwise it wont go thru
thanks!
Old Jan 26, 2005 | 12:55 PM
Brad99SD's Avatar
Brad99SD
Did you get the emails Fisherg7???? Let me know.
Old Dec 10, 2006 | 10:31 PM
musicman1's Avatar
musicman1
Just purchased a 2000 350 SD without a manual, tried using the one from my 150 but everything is different. WOuld it be possible to get a copy of those pages?
Old Dec 14, 2006 | 08:13 AM
Brad99SD's Avatar
Brad99SD
Wow thank god for the email it sent me to reply, I havent been on the site in a while. Sure I can scan in some copies for you and email them to you if you have an email. Let me know if you do, if not I will try to get them to you some other way. Unfortuanately I don't have the pickup today, driving my Bird Super Coupe to work. But I will get them for you tomorrow.
Old Dec 14, 2006 | 09:38 AM
Headviking's Avatar
Headviking
Try this web site for your manual https://www.fleet.ford.com/maintenan...ls/default.asp
Headviking
