1966 - 1977 Early Broncos
Rust Converters on Floorpans
Old Jan 24, 2005 | 10:29 PM
Ford Blue's Avatar
Ford Blue
Has anyone used Rust Converters on their floorpans and which product do you like the best? Thanks
Old Jan 25, 2005 | 12:58 AM
mauicruza's Avatar
mauicruza
Are you talking about the white creamy stuff that you brush on rusty areas?
Old Jan 25, 2005 | 10:07 AM
Ford Blue's Avatar
Ford Blue
I'm speaking about products like Por-15, Zero Rust, and Rust Bullet has anyone had used these products and which one do you like the best?
Old Jan 25, 2005 | 11:52 AM
chillyF250's Avatar
chillyF250
I used Corroless from Eastwood on my '66, works great but you do need to topcoat it as it's somewhat soft. Eastwood "Miracle Paint" is also great stuff...I think it's basically the same as Por15. Extremely hard, but it also needs a topcoat because it breaks down in UV light.
Old Jan 25, 2005 | 05:07 PM
mauicruza's Avatar
mauicruza
Couple of years ago I tried one from NAPA, from their balkamp line. As chilly250 said, I needed to top coat it. I didn't care for it because, after a year surface rust came thru even with a primer sealer and 3 top coats using urethane paint. I should have just cut the cancer out clean and restitch new steel.
Old Jan 26, 2005 | 08:53 PM
CJBoo's Avatar
CJBoo
i like the miracle paint its worked the best for me im putting it on all my new parts that im putting in to
Old Jan 27, 2005 | 12:37 AM
jlong1974's Avatar
jlong1974
i used por15 with great results. I would use it again. the key is to follow the directions 100%
james
