ignition module problems?
Old Jan 24, 2005 | 08:37 PM
4speedvan's Avatar
4speedvan
Question ignition module problems?
Well, here's my current problem, 1979 E150 with a 302, I have tuned everything up and the van runs horribly and loads up on fuel. Is there anyway to test the ignition module?
Old Jan 24, 2005 | 10:28 PM
forder's Avatar
forder
I had a similar problem years ago with a `79 Ford LTD 302. It was an intermittent problem (no power, barely crawled, black smoke and it wasn`t the fault of the carb). Turned out to be the Ignition Module. All I did was replace it and my problem was solved. Hope this helps you.
Old Jan 24, 2005 | 11:04 PM
pfogle's Avatar
pfogle
Take it off, Auto Zone, Pep boys, checker, advance auto will check them for free.
Old Jan 25, 2005 | 05:36 AM
trike1946's Avatar
trike1946
I had a 79 until the flood last summer. My module stsrted to melt. It was mounted too close to the engine. I mounted the new one as far away as I could with the existing wires, and made an aluminum shield in front of it. Seemed to work ok after that.
Old Jan 26, 2005 | 06:22 AM
4speedvan's Avatar
4speedvan
Thanks everyone, I'll let you know how I make out
Old Jan 26, 2005 | 06:48 AM
4speedvan's Avatar
4speedvan
module tested out fine
Old Jan 26, 2005 | 07:02 AM
trike1946's Avatar
trike1946
How is the carb working?
Old Jan 26, 2005 | 10:17 AM
pfogle's Avatar
pfogle
You've ruled out the ICM, now is there any play in the distributor? Take it out, there should be no movement side to side in the shaft. There is also a PIP sensor in the distributor, it can be replaced too... It may be bad, my '82 used to cut out, not backfire, but would stumble and sometimes stall.. It was the pip in the dizzy... It could also be a sticking float in the carb.
