oil leak
Old Jan 24, 2005 | 06:53 PM
Gwilkrrs's Avatar
Gwilkrrs
oil leak
2002 psd 60k miles. i noticed that the pass side of ooil pan and the flywheel cover are wet and theat there is a drop of oil on ground. top of engine looks dry. the turbo hose has residual on it. were is it coming from?
Old Jan 25, 2005 | 12:42 AM
71Fordpu's Avatar
71Fordpu
howdy
i have a 94 powerstroke and have a oil leak it is comming from just below the turo pedistal i dont know wheather you have checked this out or even if the newer trucks are set up the same. thair are a couple of little o rings you can replace betwen the turbo and the pedistal and the pedistal and the block they are a pain in the *** to replace. just a thought
good luck Devlin
