1978 - 1996 Big Bronco
Freeze Plug
Old Jan 24, 2005 | 02:55 PM
neilbaud's Avatar
neilbaud
Thumbs down Freeze Plug
Hi all, I'm new to this thread, does anyone knows where the Freeze Plug is located on a 1989 Ford Bronco? 5.8 engine, also, if there's a diagram of it, can it be posted for viewing? I'm also looking on information on how to install the Freeze plug, I beleive it is leaking antifreeze on the Driver's side. Thanks, Neil
Old Jan 24, 2005 | 03:28 PM
jacque_strap's Avatar
jacque_strap
Theres more than one. I'm not sure the exact locations on a 5.8L (cause I have a 5.0L) but they're right on the block, you can't miss em. Just pry the old one out, pop the new one in. (as a trick, use a little hand soap on the "O" ring, it'll go in easy and the soap will wash away leaving in tight).
Old Jan 24, 2005 | 03:32 PM
neilbaud's Avatar
neilbaud
Thanks Jacque, quick question, are the freeze plug located above the exhaust manifold or under it?
Thanks
Old Jan 24, 2005 | 03:34 PM
jacque_strap
Under it. (i think..... yeah under it)
Old Jan 24, 2005 | 03:37 PM
jacque_strap
Almost forgot, there are freeze plugs in the back of the block as well. (sounds like you've pinpointed your leak, but thought I would throw that in) I also forgot to mention to use some kind of sandpaper to clean out the hole to make sure you get a good seal. Then just tap the new one in with a hammer. This is an annoying job, your gonna get anti-freeze everywhere, if you have a drain on your rad that helps a little. GOOD LUCK!
Old Jan 24, 2005 | 03:55 PM
neilbaud's Avatar
neilbaud
I'm not going to use the original one, I will replace it using the Rubber Freeze Plug, it's a lot easier to deal with than the original one.
Neil
1997 - 2003 F150
39
Jan 2, 2007 03:30 PM
JohnT
Apr 23, 2005 05:56 PM
Lila
Aerostar
16
Jul 24, 2004 10:45 AM
Pagemaker
Aerostar
Dec 13, 2003 11:13 PM
dtpatt2
Oct 6, 2003 08:36 PM
