1978 - 1996 Big Bronco
manual tranny problems
Old Jan 24, 2005 | 03:20 PM
bigbodybronco's Avatar
bigbodybronco
it was driving fine no clutch slip or anything then i shut it down and went to drive it again and there was nothing there but i still had a clutch pedal. I am able to shift through all gears with out pressing clutch with no movement no noise and no vibrations any help would be greatly appreciated because i dont want to tear it apart and find that its something that i cant fix myself
Old Jan 24, 2005 | 04:02 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Welcome John, to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE. Stick
around someone will be by shortly...to answer your question.
We are pleased you have chosen the best source for Fords!
See you on the boards.
Enjoy FTE …..
