Aerostar Ford Aerostar
Steering rack bolt removal
Old Jan 24, 2005 | 11:56 AM
CharlestonSC's Avatar
CharlestonSC
Unhappy Steering rack bolt removal
I give up. How do you remove the bolts that hold the steering gear/rack to the frame. Aside from getting it up on a lift and getting better leverage, I'm not sure how to break them free. It's a 1993 3.0 with 230,000 miles on it, and I'm pretty sure it has never been replaced. I've got it sitting on jack stands right now. The bolts are about 14-15 inches off the ground to give you an idea of the clearance I've got. If I use a pipe on the handle of a ratchet to extend out the side, unless I remove the sway bar, I don't have any room to move the pipe. Would an electric impact wrench work? I'd hate to put it all back together and drive it to a shop after putting in this much so far. please help
Old Jan 24, 2005 | 12:07 PM
copper_90680's Avatar
copper_90680
Don't try to open the bolts. Just use something to hold it. Open the nuts on the other side instead. I'm surprised you are having problems with that. I also have a '93 3.0L and mine came out pretty easily. The nuts are self-locking, so you'll continue feeling friction until they are off the bolts completely, but aside from that I had no problem. Shouldn't be more than a 1-hr job.
Also, when you tighten the bolts, the correct torque is much less than indicated in some manuals. I'll post the correct torque after I got home tonight. Don't go by the manual you have, or you may bust the new rack.
Old Jan 24, 2005 | 12:27 PM
CharlestonSC
Do I need a deep socket to get the nuts off? I don't happen to have one of those, but there's a pawn shop right up the road.
Old Jan 24, 2005 | 01:49 PM
copper_90680
Yes, it helps if you have a deep socket. I forgot what size it was, 27mm I think. Otherwise, you might be able to do it with just a wrench.
Old Jan 25, 2005 | 06:49 AM
CharlestonSC
I tried a 13/16 on the front, and it seemed to fit pretty snug, no play at all. Is the nut the same size?
Old Jan 25, 2005 | 10:43 AM
copper_90680
The nuts in the back is either the same size (13/16 or 21mm), or (15/16 or 24mm). The 27mm size I quote was wrong. I don't have anything that big
IttyBittyX
Oct 18, 2012 10:37 PM
hollygreenman
33
Nov 10, 2010 11:13 PM
poffutt
General Automotive Discussion
15
Aug 2, 2005 07:56 AM
Lumpty
Sep 27, 2004 08:09 PM
bhiebert
Aug 27, 2004 10:47 AM
