Sponsored by: Real Truck
After Plow Maint.
Old Jan 24, 2005 | 10:47 AM
koziol41's Avatar
koziol41
Smile After Plow Maint.
My first season of snowplowing with my 2001 f250sd i do my own driveway which is about 125 feet long.What kind of maint.should i do after the snowplow season is over in spring truck is well cared for (garged kept,oil changes every 3/3000 etc)only has 19,000 miles.Any help would be great
Old Jan 24, 2005 | 05:53 PM
04superduty's Avatar
04superduty
what type of plow do you have? you should change your plow fluid in the fall.
Old Jan 24, 2005 | 06:18 PM
SMiller's Avatar
SMiller
I change my fluid about twice a season, but I plow alot, fluid is always dirty, just do the regular service things, oil + filter every 3000, tranny and filter every 30,000 to 50,000, grease everything every 5000-6000 miles, air filter as needed, I changed my front and rear ends at 50,000 miles, there both dirty at that point, chage transfer case fluid every season, it is always very dirty, only takes two quarts of atf and 5 min. tops, don't forget to keep plenty of dialectrical? grease on the plug-ins for the plow connectors, just keep a eye on everything.
