squealing noise
Old Jan 23, 2005 | 08:28 PM
aiminforthesky's Avatar
aiminforthesky
squealing noise
i've got a 1990 F-150 4x4 lariat with 120,000 miles on it and it has a squealing noise coming from somewhere from the transmission back. only does it once in a while and the driveshaft is not rubbing on anything. i cannot seem to see any problems as the u joints were both tight and the pinion and output shaft bearing seem tight. it only makes the noise at low speeds (10 mph or less) and sometimes is intermittent squeals.............stops...........squeals....... .........stops........ any ideas would be appreciated.
KoolAidMan888
Nov 18, 2016 01:23 PM
twall_SD250
Aug 19, 2011 08:31 AM
vincewood30
Modular V8 (4.6L, 5.4L)
Mar 24, 2007 04:25 PM
300-6cyl
1983 - 2012 Ranger & B-Series
Aug 16, 2006 12:24 AM
sa_rains
19
Dec 3, 2005 11:39 PM
