2001 ranger won't start
Old Jan 23, 2005 | 05:45 PM
ohiof150nut's Avatar
ohiof150nut
hi i put a new fuel pump in the wifes ranger 6 months ago, but the check engine light came on, so i had her take it to autozone they said it said a bad connection what ever that means, i checked everything all the connections
to do with the fuel system, but it always started untill now, i went to the store this morning and on the way home it quit running, i got it towed home and i started to try and figure out what is wrong i sprayed gas in the air intake tube and it started , then i tried spark and i have spark but you turn the key on and you can't hear fuel pump, somehow something is sending a signal to the fuel pump not to send gas i guess can someone please help me thanks alot
Old Jan 23, 2005 | 05:55 PM
Bob Ayers's Avatar
Bob Ayers
First, welcome to FTE!!!
If you can't hear the fuel pump running, you need to determine if it is getting power. Test for 12V at the connector on top of the fuel tank if possible (when turning the key on). If there is 12V, then the problem is probably the pump. If there is no 12V, then trace back and check things like the inertia fuel cut-out switch, fuel pump relay, etc. .
Good luck!!
Old Jan 23, 2005 | 06:31 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
Test for the presence of fuel and pull codes.
Wolf41035
19
Sep 19, 2016 07:28 AM
jermill_08
43
Jan 23, 2016 06:13 PM
Alex Dennis
Sep 12, 2015 04:17 PM
Fred Furrer
30
Sep 8, 2015 09:08 PM
Allyn Mitchell
Feb 26, 2014 04:44 PM
