Sponsored by: Real Truck
bump steer update
Old Jan 23, 2005 | 05:07 PM
Badford's Avatar
Badford
bump steer update
i just finished working on my front end, and for those of you that think you can't get your front axle off center when installing a lift, well you can and i did! mine was over a 1/4 off ! i used a fabtech adjustable trac bar to correct the problem, and i finally have the bump steer under control.
Tony
Old Jan 23, 2005 | 07:18 PM
SoCalDesertRider's Avatar
SoCalDesertRider
Yep, because the track bar swings in an arc, changing the ride height without changing the track bar length or trac bar bracket hieght causes the axle to be offset to one side. Glad you got it worked out!
Old Jan 23, 2005 | 08:33 PM
Dennist's Avatar
Dennist
Ours bumps while it is still stock!
Old Jan 23, 2005 | 08:35 PM
Dennist's Avatar
Dennist
Cool
Our 2004 F350 bumps at the stock height...... now to figure that out.
Old Jan 24, 2005 | 12:49 AM
99f350sd's Avatar
99f350sd
Tony
Now I hope you put that track rod in correctly. With the truck sitting level you are supposed to adjust it so the bolt just slips in. Are you saying that you cranked it to pull the front end over? 1/4 inch.
Glad it worked for you.
Dick
Old Jan 24, 2005 | 03:55 AM
Badford's Avatar
Badford
the problem originated from my lift. i installed a 2.5" leveling kit with a skyjacket 2" trac bar bracket and i had to move mountains to install the stock bar!!!!!!! and that must have offset my axle. so i threw all that crap away, and purchased a fabtech adj bar and pulled the axle back to center....
Old Jan 28, 2005 | 06:23 PM
dmgiff's Avatar
dmgiff
Badford, I saw that you installed the Fabtech adj. track bar, as did I. Question is, how much torque did you get on the track bar bolts? And how were you able to do it? When I first did mine, I torqued it to 150 ft/lbs. I didn't know the stock spec and thought that would be enough. It wasn't. Had some creaking/rattling underneath and found out today that it was the lower track bar bolt. I had to remove the right-side tie rod just to get a socket on that bolt, and I tightened it as much as I could with a 1/2" breaker bar which is 24" long. My guess is that I might have about 200-250 ft/lbs on it now.
Old Jan 28, 2005 | 06:58 PM
99f350sd's Avatar
99f350sd
I think its like 400 ft lbs..4ft 3/4 inch torque wrench.
Old Jan 28, 2005 | 07:24 PM
Rongold's Avatar
Rongold
Talking Track Bar Torque
Hi All,
The correct torque for the 2 track bar attaching bolts & nuts is 406 foot pounds.
RON
Old Jan 28, 2005 | 08:29 PM
WA.Ranger's Avatar
WA.Ranger
From what I've read in the archives then, you would need one of Yeti's girlfreinds to step on the end of the breaker bar then. LOL
(Couldn't resist Yeti)
Old Jan 28, 2005 | 08:44 PM
99f350sd's Avatar
99f350sd
The one thing I got out of the USAF was a 4 ft 600 ft lbs monster torque wrench. 400 ft lbs is way beyond most peoples tools. You have to get a 3/4 drive or just put an air gun on it and let it go for a while, most of them are 400 or so tightening just don't over tighten too much.
Yeti's Avatar
Yeti
Hm.......pick on the guy with the fat girlfriends...I see how ya are..
Old Jan 28, 2005 | 08:47 PM
WA.Ranger's Avatar
WA.Ranger
Ah, we've all had at least one, or several in some cases, we would like to forget.
Old Jan 28, 2005 | 09:18 PM
99 sd v10's Avatar
99 sd v10
The spec I got with a lift kit was 369 ft lb per ford's track bar requirment.
Old Jan 29, 2005 | 12:07 PM
dmgiff's Avatar
dmgiff
Thanks for the help you guys. I borrowed a junked motorcycle fork tube from a friend to slip on my breaker bar and it worked like a champ. It was about 3 feet long and I got about 185-210 pounds on it. Yeah, I know it isn't the smartest way to do it, but I was careful in case something broke... I think those numbers probably work out to around 400 ft/pounds. I am not a math genius, so I'm not quite sure how to come up with that figure.
