Map vs. Maf
Old Jan 23, 2005 | 04:57 PM
TryMe's Avatar
TryMe
Map vs. Maf
Does anyone know the performance diffrence,in a regular 302 EFI and a 302 mass air car ?? Is it enought gain to make a change ?
Old Jan 24, 2005 | 12:46 AM
Ford_Six's Avatar
Ford_Six
Not too much of a difference in stock form, but MAF is much more forgiving of modification than the speed-density system.
Old Jan 24, 2005 | 10:45 PM
LxMan1's Avatar
LxMan1
I am assuning that you are talking about the Mustang engines? Bone stock, the Speed-Density cars were a little faster because the stock MAF was only 55mm and actually restricted airflow to the stock 60mm TB.
But if you are going to add better heads, larger cam, etc, a MAF system with a C&L 73mm MAF will run much better. The MAF can adapt the the added airflow thru the engine as to where the Speed-Density system can not.
Also, the Mustang and Lincoln Mark VII use a SEFI system which fires each injector separately where as the standard 5.0 such as a truck, t-bird/Cougar, towncar, Crown Vic, etc use a batch fired system that fires one bank at a time.
hunterkane
Mar 15, 2008 11:31 PM
Franklin2
May 13, 2002 08:18 PM
drumnbum
Feb 12, 2002 02:19 PM
jim henderson
Dec 11, 2001 04:37 PM
thelonerangerxlt
Oct 23, 2001 08:40 PM
