400 build problem
Old Jan 23, 2005 | 04:42 PM
bjmyers's Avatar
bjmyers
400 build problem
We are rebuilding a 400 to go in a 79 bronco, the motor turned fine at the crank before we got it in the truck, but now that its in it wont turn at all. Anyone have any ideas on what might be wrong?
Old Jan 23, 2005 | 05:19 PM
Nod's Avatar
Nod
Won't spin
Could the tranny,starter or drivetrain be locked up?Does the starter engage but won't spin the engine,could you have mixed components or is this a remove and replace job?Is the negative strap from the body to the engine hooked up?Possibly a sylenoid start wire has been knocked loose.Dead battery?Starter cable hooked up but not tight?Did you try pulling the plugs and then try and crank it over?Last but not least is there any way the cylinders or cylinder could have filled with water or antifreeze and caused a hydrolock? Thats all I can come up with,hope this helps.
"bowties in the rearview mirror"
Old Jan 23, 2005 | 07:05 PM
mark a.'s Avatar
mark a.
Is the converter in all the way ?
Old Jan 23, 2005 | 08:51 PM
bjmyers's Avatar
bjmyers
theres nothing on the motor right now but the block heads intake and carb. we were trying to turn the motor with the crankshaft bolt to bolt the tourqe converter up. but it will not turn over at all.
Old Jan 24, 2005 | 04:36 AM
BradysDad's Avatar
BradysDad
the converter is not in all the way.
Old Jan 24, 2005 | 06:16 AM
Torque1st's Avatar
Torque1st
Posting Legend
Pull it back out and check. Do not force anything.
Old Jan 24, 2005 | 11:50 AM
bjmyers's Avatar
bjmyers
Well we finally got the motor to turn over by prying the fly wheel around. got every thing bolted up. I guess the motor was just really tight. Thanks for the info
monster.dude
Mar 7, 2011 06:07 PM
global247
Oct 10, 2008 09:15 PM
4wheeling79
Apr 1, 2007 10:28 PM
TMI
Aug 22, 2006 07:40 PM
woodman209
Mar 9, 2003 09:40 PM
