enough cfm
Old Jan 23, 2005 | 01:22 PM
built_usa_tough's Avatar
built_usa_tough
enough cfm
i just installed a 600 holley and stock cast 95lb iron intake my motor is all stock but it is fixin to have a set of headers will that matter?
Old Jan 23, 2005 | 02:17 PM
gtex's Avatar
gtex
Should be plenty. You'll need more displacment, bigger cam and/or higher flowing heads/valves to need any more than 600. The 600 Should be a good match for your motor. Is it a vacuum secondary carb?
Old Jan 23, 2005 | 03:23 PM
WillyB's Avatar
WillyB
I agree with the 600 cfm, but just to double check, what size engine do you have, and how high will you be reving it?
Old Jan 23, 2005 | 04:43 PM
built_usa_tough
yes its vac. sec. and it my not be good but ive ran it at 36-3800 for a few miles and it took it like a champ
