Explorer Horn
Old Jan 23, 2005 | 12:27 PM
vtm's Avatar
vtm
Explorer Horn
The horn on my 2000 Explorer Limited has quit working - the alarm is OK.
Any ideas on how to repair
Thanks
Old Jan 26, 2005 | 08:32 AM
bryan42's Avatar
bryan42
Do they use the same horn? You need to determine if the horn itself is broken or if there is a problem turning it on. Areas that might be a problem would include the horn switch, a relay, wiring connections, and of course the horn itself. I'd work backwards, testing the horn, the relay, and finally the switch to try to isolate the problem.
Harbor Freight has an air horn for $13 that I'm currently adding to my wife's 96 Explorer.
