door tags read
Old Jan 23, 2005 | 10:36 AM
War Wagon's Avatar
War Wagon
door tags read
How,s it going today. I'm trying to find information about my military '60 ford panel.The door tags read
make & model Ford-100-82A
date of manu. 1/25/60
chassis or vehicle code 7110
service & order CD-963936
chassis serial 15163
engine ZE-4515
Gloss green
operators inst. SE-704-60
maint & rep manual SE-717-60
parts ident list PA-761-60-PA-761-59
It would be nice to find more about it like how many built , where it was built and what all these numbers mean . Any help would be GREATLY appreciated. Thanks Dan
Old Jan 23, 2005 | 12:10 PM
barry's Avatar
barry
What you have there is the military nomenclature for each servicin g arm, like the motor pool. It terlls you which pulications to use when working on the vehicle. You've listed the parts manual, operators manual and the maitenance manual. Look for the vin number that would start with "F10*******, it's about 10-11 character long. If you wanted the military manuals, I'd check Potrayal Press or the MVPA. They have a web site. I did military vehicle restos for 22 years and there's tons of manuals out there. Just look for the numbers you listed.
Barry
50 F-1
Old Jan 23, 2005 | 12:26 PM
Earl's Avatar
Earl
In the mid-50's, the VIN Barry mentioned was usually in the glove box and/or door column, plus it was usually stamped on the top of one of the frame rails between the front of the cab and the front axle. I don't know where the '60 stamping would be, but there are a bunch of 57-60 folks who can help you with that if you can't find it.
Old Jan 24, 2005 | 06:19 PM
War Wagon's Avatar
War Wagon
There is no vin on the panel ,it was registered with the service and order # for the vin.The insurance place gave my dad a serial # sticker to stick in the glove box.so i"ve been told by my dad.
Old Jan 24, 2005 | 07:00 PM
barry's Avatar
barry
You may have to look on the top edge of the frame to see if there's a Ford Vin on it. Look on both sides from the shock mounts back to just under the cab. If not, unless you find the military manuals, there may be no way to trace. The service and order number you listed is also considered a batch number. One of the ord manuals you listed may have the batch numbers broken down.
Barry
Old Jan 24, 2005 | 07:54 PM
mr4speedford's Avatar
mr4speedford
On a 1960 ford truck the vin is on topof the passenger side frame rail inbetween the front axel, and shockmount if you can picture that. -4speed
Old Jan 25, 2005 | 07:12 AM
War Wagon's Avatar
War Wagon
The original frame was tossed over 20 years ago .
Cubawashere
Pennsylvania Chapter
May 30, 2014 02:42 PM
ozzy460
18
Dec 22, 2010 01:10 AM
BBF250
Sep 21, 2005 11:32 PM
se_911
Sep 22, 2004 08:10 AM
