Brake Problem
Old Jan 23, 2005 | 09:15 AM
MercM47's Avatar
MercM47
Brake Problem
1949 Mercury M47 (Ford F-1). Brake pedel slowly goes to full hard...have to open a wheel cylinder to release pressure.
Pressure does not dissipate when truck sits over night, pedel still at full pressure.
Unable to determine if the pressure build up is from brake usage or heat transfered to lines...cannot find any line close to heat source.
Have changed the check valve twice and still the same problem...could it be the master cylinder itself?
Old Jan 23, 2005 | 08:57 PM
MercM47's Avatar
MercM47
Brake problem
also, bypass opening is clear
Old Jan 23, 2005 | 09:02 PM
Madathlon's Avatar
Madathlon
Sounds Like U may have a line blockage.. have U tryed back feeding the system?
Old Jan 23, 2005 | 09:08 PM
MercM47's Avatar
MercM47
not yet but the lines are new, stainless and smooth bends...will try in the morning...thanks
Old Jan 23, 2005 | 09:26 PM
mtflat's Avatar
mtflat
I'd replace the master cylinder - sounds like its not releasing. Rebuild or replace.
Old Jan 24, 2005 | 12:08 AM
Overkill-F1's Avatar
Overkill-F1
Is there play in the adjustment to the pedal? ...Terry
Old Jan 24, 2005 | 04:25 AM
MercM47's Avatar
MercM47
after a few minutes the pedal is as hard as a rock...no play whatsoever. Sometimes after sitting overnight it will go back to having play, other times its still hard as a rock despite sitting for hours.
Old Jan 24, 2005 | 05:05 AM
scrape's Avatar
scrape
i'd make sure u have free play at the master cylinder
cya..gary
Old Jan 24, 2005 | 06:11 AM
MercM47's Avatar
MercM47
its not the adjustment...theres plenty of play after bleeding and adjustment. Its after use/time that causes it to build/maintain pressure.
I have rebuilt the master cylender with the same results so I am questioning if the master cylinder may be defective...
Old Jan 24, 2005 | 07:59 AM
GreatNorthWoods's Avatar
GreatNorthWoods
Merc,
Check the brake pedal rod and be sure that when the pedal comes up that there is no pressure on the rod. It sounds like the rod is not retracting enough to allow the fluid to come back into the master cylinder. I had this problem once and had to shorten the rod.
Vern
Old Jan 24, 2005 | 08:00 PM
MercM47's Avatar
MercM47
ok...adjusted the pedal rod to the minimum travel and max play...bled brakes, adjusted each brake and confirmed no line blockage...within 5 minutes of normal city driving she again went to full hard.
Totally frustrated!!!
Old Jan 24, 2005 | 08:03 PM
Madathlon's Avatar
Madathlon
Do U have Disk/Drum, Drum/drum/ or disk/disk? U may have a stuck slave or caliber.. Or if U have power brake.. U maybe lousing Vac to the booster.. Need to know.. is there a lot of cam? or a bad Vac Loc on the Vac feed line?
Old Jan 24, 2005 | 08:32 PM
MercM47's Avatar
MercM47
Drum/Drum....all original. I checked the wheel cylinders and there ok
Old Jan 24, 2005 | 08:35 PM
Madathlon's Avatar
Madathlon
Ok I dont know if ther power brakes or not ON a OEM 49 M47.. But if al else checks out.. U may have a bad Booster or master...
Old Jan 25, 2005 | 07:18 AM
GreatNorthWoods
Merc,
You said your brake lines are new,but what about your front and rear brake hoses? Are they new also? I have heard that brake hoses can become clogged enough to allow pressure through but since the return pressure isn't nearly as high, the fluid is retained in the wheel cylinders. This would be a pretty rare situation, but that's all I can come up with.
Vern
