Brake Problem
Old Jan 25, 2005 | 11:31 AM
MercM47's Avatar
MercM47
Everything is new and checks outs...no blockage. I think MFalt has it right on the ball, there is something wrong within the Master Cylinder. Just going to have to replace it.
Thanks to everybody for your help!
LC
Old Jan 25, 2005 | 09:43 PM
51ford fan's Avatar
51ford fan
I had the same problem years ago. I suspected that there was not enough free play in the push rod. I loosened the master cylinder and added a cut flat washer between the booster and master cylinder to make sure. Problem solved, I removed the booster and took it back to the parts store. We discovered the booster was the wrong one.
Old Jan 26, 2005 | 10:46 AM
dmptrkr's Avatar
dmptrkr
When brakes are locked up loosen a fitting at the master cylinder. If the brakes release then the problem is in the master cylinder. If the brakes do not release then loosen the fittings or bleeders at the wheel cylinders. When brakes release you know which line/cylinder has a problem.
Old Jan 26, 2005 | 11:19 AM
Jag Red 54's Avatar
Jag Red 54
It will interesting to know the outcome. Please share your remedy. John
Old Jan 26, 2005 | 04:55 PM
Jacques's Avatar
Jacques
Hi MercM47, ******** type="text/javascript">gister("postmenu_2339692", true); </script> I had a similar problem, which was resolved through the gracious help of FTE members. I can't post links on this forum, but if you put the forum's URL in front of this: /forums/showthread.php?t=285710 it should get you there. The message is number 285710, or you could carry out an advanced search & look up the questions that I have posted as "Jacques". I hope that your fix is as easy as mine was!!! We would be very interested in hearing how you resolve your problem.
Hope this helps,
Jon
Old Jan 27, 2005 | 07:57 AM
snipa's Avatar
snipa
Check for overfilling of brake fluid in the master cylinder. If its to full near the top, the brake fluid heats and expands, thus tightening up after you drive for a awhile
