Sponsored by: Kumho
ABS light stays on
Old Jan 22, 2005 | 06:22 PM
stevieray's Avatar
stevieray
ABS light stays on
I recently had an major elecrtical failure where the headlights and engine and dash lights all failed at the same time. I pulled to the side of the road and shut of the headlights and ignition. I then restarted the engine with no problem but as soon as I turned on the headlights the engine died again. I was able to limp it home without the lights. The only side effects were that the left turn indicator light was on but dim and the ABS light was on too. I found the electrical problem to be a bad ground wire on the drivers side at the cross brace that the radiator is mounted to. The wire goes into the main harness where the left headlight wires come out. All is well now except that the ABS light is still on. It goes out when the engine is started but comes back on again right away. The fuse in the dash is ok as is the ones under the hood. This is a '93 F150 4x4/302 5speed. Any thoughts? Cheers, Stevieray.
stevieray
1997 - 2003 F150
Jan 16, 2011 07:25 PM
stevieray
1997 - 2003 F150
Apr 18, 2007 11:44 PM
barebackjake
20
Jan 1, 2005 01:56 PM
Chaos 95
Electrical Systems/Wiring
Oct 19, 2004 04:27 PM
stevieray
Sep 18, 2001 05:36 AM
