yet another "how much power" post...
Old Jan 22, 2005 | 04:26 PM
topdeadcenter's Avatar
topdeadcenter
Hey guys,
I am about to screw together my 302 and I was wondering an approximate on hp/tq. I AM NOT BUILDING a race motor. This is just a "cool" cruiser for a future project (50's f100).
I am running:
1972 block (early 1973 casting) .030 over.
stock 1972 heads w/ 58.4 cc chambers,
Flat top pistons, (I think that should put my compression ratio around (9.3),
Cam: 214/224 dura at .050, w/ .472/.496 lift , 112 lobe centers
and for intake: (before you read, I KNOW that this is WAY too much for this engine, but I don't care) EdelBrock F-28 dual quads, with 2 500cfm AFBs, and progressive linkage.
Is there is more you need, just ask. I just want a "ballpark" figure.
thanks!
Mike
Old Jan 23, 2005 | 12:14 AM
Kemicalburns's Avatar
Kemicalburns
to much carb and that motor will fall on its face. but hey it will look kewl with the hood open right
Old Jan 23, 2005 | 07:23 AM
TheWiz427's Avatar
TheWiz427
I'm with Kemicalburns on this one! It's definitely not going to run good at all. I would suggest seeing that it's basically a stock setup that a good dual plane intake and a small 4bbl would work quite well. If your going just for looks then go ahead but your sacrificing driveability with that setup.
Just my
Old Jan 23, 2005 | 08:25 AM
stevef100s's Avatar
stevef100s
That's a mild cam, and perfect for a 50's F100 cool cruiser. The progressive linkage will make that setup streetable, but tuning will be a bitch, and I'm not a big fan of the Carter AFB/Edelbrock/Weber line of carbs (they're all the same).
They're good carbs, but I have a tough time tuning them for custom applcations, such as yours. That is a good intake, but the stock heads are going to limit your power output. The heads have more of an effect on horsepower then the cam does. Most likely you'll have around 300 hp. Maybe somebody here will run it through their desktop dyno, so You can actually get your question answered, without a bunch of opinions. lol
Old Jan 23, 2005 | 09:46 AM
topdeadcenter
Thanks Steve! I knew I was going to get the "it won't run" opinions when I posted it. But my old man (a mechanic in the late 60's early 70's) installed a ton of over the counter dual quad set ups on "stock" mustangs. I am not a big fan of the AFB carb either, but holley doesn't make a carb that fits I e-mailed their tech support, hoping that the 390 cfm would fit, but alas it won't...
Kemical and the Wiz~ I know it is not going to be a race car! Just a cruiser, but when I pop the hood, people say "COOL!" As for the engine being basically stock, other that the displacement and the heads, what else could I change? I don't believe that any factory 302 came with that cam and that compression combined
Progressive linkage is the key to any multiple carb set-up.
Mike
