A little head work....
Old Jan 22, 2005 | 12:03 PM
jesse1385's Avatar
jesse1385
Rebuilding a 86' 351W HO for my pickup and was thinking of maybe boosting the compression a little while i'm at it. Will be running stock pistons and heads. Should I have the heads milled a little and if so how much? Thanks.
Old Jan 22, 2005 | 04:15 PM
stevef100s's Avatar
stevef100s
Higher compression means having to use premium fuel, and or retarding the timing. A little porting work would do more for you then boosting the compression. If you do mill the heads, just have enough taken off to make a good sealing surface.
Old Jan 23, 2005 | 02:20 PM
jrocco's Avatar
jrocco
Tak a look at the Ford GT40P Heads. They have a 59cc Combustion Chamber and flow real good for stock heads. With stock dished pistons you will end up with about 9.0:1 CR.
I have them on my 351W
