Cluster gauge swap wiring?
Old Jan 22, 2005 | 01:30 PM
jmurphy_5's Avatar
jmurphy_5
Question Cluster gauge swap wiring?
i have gauge cluster w/tach out of 1995 f150 and i want to install it in 1993 f150 that didnt have the tach. the wiring harness looks the same and plugs in the same but there was a change in a few wires. this causes a short. does any know the wires that need to be switch?
thanks for any help that you can offer.
Last edited by Mil1ion; Jan 22, 2005 at 07:11 PM. Reason: Title change to best reflect the nature of the TOPIC
Old Jan 22, 2005 | 07:19 PM
Franklin2's Avatar
Franklin2
Look at both clusters carefully. Do they both have ammeters, or does one have a voltmeter, and the other an ammeter? Have you considered possibly taking the tach itself out of the cluster and putting it in the old cluster(will it fit)?
Old Jan 22, 2005 | 09:04 PM
jmurphy_5's Avatar
jmurphy_5
1st sorry about title.
the tach will not fit into old cluster, but after about an hour with ohm meter i was able to find what two wire needed to be changed. wires B11 and B12 from wire harness B had to be move to A1 and A14 on wire harness A. the old A1 didnt have a pin in the harness so I didnt have to move that wire but the old A14 did and i moved it to B11.
the old clusters amp circut light was located at B11 & B12 and new Cluster amp circut was located at A1 & A14. If you Don't make this change you will have a short That causes voltage regulator to kick in and out. after I made these changes the cluster is working fine.
Handegard
Feb 22, 2014 11:27 AM
Nathan Plemons
Jun 14, 2013 01:56 PM
FLJ
Electrical Systems/Wiring
May 30, 2009 04:01 AM
FourPointTwo97
1997 - 2003 F150
Nov 12, 2007 10:04 PM
Rintin69
Mar 27, 2004 01:20 PM
