Acronyms
Old Jan 22, 2005 | 08:17 AM
jkpruitt's Avatar
jkpruitt
Question Acronyms
I believe my HGAF adapter may be leaking. Or maybe my WALTFA sensor is not reading the AAUFC T/C. What do you think? I have head that I can purchase a NFST converter to bypass the original HGAF, WALTFA, and the AAUFC. Does anyone know anything about these? You folks and your Acronyms
FUJIMO
Old Jan 22, 2005 | 09:06 AM
barebackjake's Avatar
barebackjake
haha you funny guy.
Old Jan 22, 2005 | 11:47 AM
BigRed350's Avatar
BigRed350
FUJIMO
I think your WALTFA sensor is just fine. From what you describe, the HGAF adapter just may have a problem, but if it did, you would know it! I would NOT recommend a NFST converter though....there are too many guys who have done that mod and most of them regret it. Whenever you bypass the AAUFC, the truck will not start under 30 degrees, will stall when the speed reaches 48 MPH and will blow out large plumes of purple smoke.
Saved another one.....
Old Jan 22, 2005 | 12:16 PM
jpm2591's Avatar
jpm2591
I agree, too many acronyms. If this site operators can find a way to redirect a URL to one of the forum sponsors then maybe they can come up with a way to change the acronyms. ????
Old Jan 22, 2005 | 12:43 PM
jkpruitt's Avatar
jkpruitt
Just maybe!
I took you advice on the WALTFA sensor; mine is fine, although you missed on the HGAF adapter, it was also not the problem. As you stated, I did NOT do the NFST converter MOD. I agree, there are too many guys who have done that mod and most of them regret it. My AAUFC was OK, although I did have to take it to Auto-Zone and have them recalibrate it using a TIGZZ-45-DIS recalibration spectrometer; with the special PSD plug and high pressure hose.
I found a way around the "not starting when the temperature drops below 30 degrees"; I don't shut it off. The large plumes of purple smoke are not an issue either, they remind me of the 60s. <O></O>
<O
Does anyone know where I can get an KFVV-9-2-FU-12-4A "PSD to VW Microbus" Transmission Adapter?<O></O>
<O
Saved another one.....[/QUOTE]
Old Jan 22, 2005 | 12:45 PM
Quadzilla's Avatar
Quadzilla
Here's an incomplete list of acronyms:
2x4 =Two Wheel Drive
4L100 =Automatic Transmission 4 Super Duty Trucks
4x4 =Four Wheel Drive
ABS =Anti-Lock Braking System
AC =Air Conditioning
AIC =Auxiliary Idle Control
APCM =Auxiliary Power train Control Module
ATF =Automatic Transmission Fluid
BARO =Barometric Pressure Sensor
BB =Bulletin Board
BBS =Bulletin Board System
BCA =2nd Best Bearing Company
BTW =By the way
CC =Crew Cab (4 door)
CDR =Crankcase Depression Regulator
CPS =Cam Positioning Sensor
DORA =Dealer Order Receipt Acknowledgment
DRW =Dual Rear Wheels
DTC =Diagnostic Trouble Code
DVOM =Digital Volt-Ohm Meter
E4OD =Auto Transmission on Pre-'99 Ford Pickups
EEC =Electronic Engine Control
EGT =Exhaust Gas Temperature
EOT =Engine Oil Temperature
FAQs =Frequently Asked Questions
GM =General Motors
GP =Glow Plug
GPR =Glow Plug Relay
GVWR =Gross Vehicle Weight Rating
HEUI =Hydraulic Actuated Electronic Controlled Unit Injector
IAT =Intake Air Temperature Sensor
IDM =Injector Drive Module
IMHO =In My Humble Opinion
LB =Long Bed
LOL =Laugh Out Loud
MAF =Mass Air Flow Sensor
MAP =Manifold Absolute Pressure Sensor
OD =Over Drive
OEM =Original Equipment Manufacturer
OTC =Owatonna Tool and Equipment Company
PCM =Power train Control Module
PCV =Positive Crankcase Ventilation
PDL =Power Door Locks
PM =Power Mirrors
PS =Power Stroke
PSD =Power Stroke Diesel
PTO =Power Take Off (winch)
PTTTM =Power Telescoping Trailer Tow Mirrors
PW =Power Windows
PWM =Power Window Motor
RC =Regular Cab
SB =Short Bed
SC =Super Cab (extended cab)
SRW =Single Rear Wheel
TC =Torque Converter or Transfer Case
TPS =Throttle Position Sensor
TSB =Technical Service Bulletin
TTM =Turbo Temp Monitor
VAC =Volts Alternating Current
VDC =Volts Direct Current
VECI =Volts Direct Current
WOT =Wide Open Throttle
Copied from Steve Baz's website.
Old Jan 22, 2005 | 12:49 PM
jkpruitt's Avatar
jkpruitt
Thank you, Thank you, thank you!
I am going to print that list and stick it on the wall, so that when I visit this site I will be well versed with all of the acronyms.
You forgot one. FUJIMO
Thanks,
Ken
BB =Bulletin Board
BTW =By the way
GM =General Motors
GP =Glow Plug
LB =Long Bed
LOL =Laugh Out Loud
OD =Over Drive
PM =Power Mirrors
PS =Power Stroke
PW =Power Windows
RC =Regular Cab
SB =Short Bed
Old Jan 22, 2005 | 01:04 PM
wlihntr's Avatar
wlihntr
Quad, thats great. i think we need to and one that applies to many people on the site, including myself "tmtoh" = to much time on hands
Old Jan 22, 2005 | 01:09 PM
HeatStroked's Avatar
HeatStroked
or MYOFB............ (Mind You Own Friggin Business)
and one in which we all experience:
PMS ............."Post Mod Syndrome"
Old Jan 22, 2005 | 01:25 PM
BigRed350's Avatar
BigRed350
Does anyone know where I can get an KFVV-9-2-FU-12-4A "PSD to VW Microbus" Transmission Adapter?<O></O>[/color]
[/QUOTE]
The purple haze doesn't bother me either, it's kind of nostalgic! As for the VW Microbus tranny adapter, I haven't seen one in years. I think that swap has fallen out of favour. Most guys are now using the VW to E40D adapter in an effort to save money.
plum bob
18
May 31, 2018 12:06 PM
dloomis
Feb 12, 2013 07:20 PM
jetact
Sep 14, 2010 09:30 PM
jeff2011
Sep 7, 2009 10:54 PM
1bgredtk
Nov 9, 2004 10:26 PM
