Shaking while braking!!
Old Aug 12, 2002 | 09:41 AM
kasparsport's Avatar
kasparsport
I recently put front brakes & rotors on my 85' F-150. Since i put them in i get a bad vibration in the front end. I was on the highway doing about 60 mph & at 45 mph it started vibrating till it got down to 30-35 mph. Normal driving its fine. I also had the tie rod changed as well as wheels aligned & balanced. Any help would be appreciated. Thanks
Old Aug 12, 2002 | 10:03 AM
topo4u2's Avatar
topo4u2
Do you get the shake while you brake or just driving down the road? If when braking I suspect warped rotors, but if driving only you may want to check your front end or even the possibility of a caliper seizing. Also a wheel weigth or two may have come off.
Old Aug 12, 2002 | 10:18 AM
kasparsport
It only shakes while braking....these are new rotors & the wheels were balanced. The only thing i didnt change were the calipers...is this a sympton of failing calipers??
Old Aug 12, 2002 | 06:52 PM
Varnish's Avatar
Varnish
never seen it, but maybe the rotors didn't sit straight on there or somethin? sure sounds like warped rotors. if it were me i'd pull the wheels and check out those rotors, spin the rotor on the hub and watch for wobble against a fixed point.
Old Aug 12, 2002 | 08:27 PM
topo4u2's Avatar
topo4u2
I have to ask if your emergency brakes work? If so go down the road on some quiet street and stop with just your emergency. See if it vibrates but please make sure know one is around. You may have warped drums in the rear OR seizing emergency cable.
If rears are good then I have to go back to the front rotors or a seizing caliper but if that was the case you would have a brake pull.
Old Aug 12, 2002 | 08:38 PM
Franklin2's Avatar
Franklin2
If one of your old calipers is stuck a little, it could have rubbed the new rotor and got it hot enough to warp it.
Old Aug 12, 2002 | 09:14 PM
paveslave's Avatar
paveslave
Before you go spending money on anything else, bleed your brakes. Shaking while braking is usually a sign of air in the system as well as warped rotors or glazed pads. Since your rotors and pads were just replaced, go with a good brake bleed before you spend anymore money. If you already did that and didn't mention it, then you could start looking at your calipers, but if the shaking wasn't there before you changed your brakes, it's unlikely it's your calipers now. Good luck with it, hope you find the problem..
-Ry
-If it aint broke, fix it till it is...
-Stop telling God how big your problems are, instead
tell your problems how big your God is...
1985 F-150 302 4X4
Dana 44 TTB / 9 inch
4.56:1 Front/True-Trac
4.56:1 Rear/Detroit Locker
C-6 Tranny, NP208 Transfer
6 inch Skyjacker Class II lift
35 X 12.50 BFGoods AT's
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=6696&.jpg https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=6663&.jpg
Old Aug 12, 2002 | 09:32 PM
Franklin2's Avatar
Franklin2
It's been my experience when new pads are installed, and the piston in the caliper has to be pushed back up in the caliper with a c-clamp, there is a 50-50 chance they will stick, because usually the bore is rusted behind the piston.
Old Aug 12, 2002 | 09:33 PM
kasparsport
Thanks for all the replys..ill go through the list & let you all know what happens..thanks
Old Aug 12, 2002 | 09:41 PM
Franklin2's Avatar
Franklin2
