Sponsored by: Real Truck
Rear Wheel Well Liners?
Old Jan 21, 2005 | 11:11 PM
JeffreyK's Avatar
JeffreyK
Question Rear Wheel Well Liners?
I added these aftermarket from Mopar on my (now traded in) '03 Ram. It hides the direct view above the rear wheels into the suspension. Does Ford or an aftermarket company make something like this for my new '05 F250?Thanks
Old Jan 21, 2005 | 11:22 PM
Antacus's Avatar
Antacus
I snagged this from another post for my notepad doc, hope they are the correct numbers
fender well liners:
(2ea) F81Z*9928370*CA Front left and right
(2ea) F81Z*9928370*AA Rear Left and right
(8ea) *389358*S Plastic push pins (2 per piece)
Old Jan 21, 2005 | 11:40 PM
JeffreyK's Avatar
JeffreyK
Front left and right, I would assume this are installed at the factory and you're posting the numbers for reference?
Also these are for 2005 correct?
Old Jan 22, 2005 | 06:02 AM
jon brown's Avatar
jon brown
i ordered a set from ford for my 05 and laughed at them when i went to pick them up. they wanted 140 $ and they came with about 30 screws that they want ya to drill along ya fender well to mount . not to mention they don't gaurd much. i went to a parts store bought these black flat mud flaps(14 dollars) there about 13 inches wide /20 inches long ,used factory holes plus a hole i drilled for my trucks flaps. they protect alot more than the ford ones,alot cheaper,and look stock you can save alot of money just have to use your imagination
Old Jan 22, 2005 | 08:05 AM
RobertJohn's Avatar
RobertJohn
The things Frod calls liners are more like trash bags. They are junk. Surely someone makes an after market product that is better and does what its suppose to do.
Anyone know of any ??
Old Jan 22, 2005 | 08:00 PM
rezhawkw06's Avatar
rezhawkw06
take a look at the wheel liners for the dually and then cut them to fit your SRW.
Old Jan 22, 2005 | 08:20 PM
WhiskeyMan's Avatar
WhiskeyMan
I completely disagree with these other guys. They are not junk. I paid $100 for mine (4 total) and they are well worth it if you drive gravel roads or wheel in rocky country. If you can go $40k for the truck, what's another $100? I kicked up large rocks in my 2000 that made sizeable dents protruding to the OUTSIDE that had to be repaired and repainted. My 2000 did indeed have these from the factory, but anything you can do to your 05 is cheap insurance. These liners are the first mod I did to my 05. It took about 1.5 hours and is pretty easy. And there ain't 30 screws.
Old Jan 22, 2005 | 09:24 PM
RobertJohn's Avatar
RobertJohn
WhiskeyMan,
What kind did you order ? And from where ?
Old Jan 22, 2005 | 09:56 PM
AuRevoir's Avatar
AuRevoir
F81Z-9928370-CA/ $23.64 each Wheel Liner<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o></PRE>
F81Z-9928370-AA/ $17.95 each Wheel Liner</PRE>
This is what I paid for the liners, you'll need two of each, buy the push </PRE>
pins from Napa Auto parts, they are about 1/3 the cost</PRE>
<o></o> </PRE>
Amish65F100
Apr 27, 2017 03:43 PM
jjdhog1975
Feb 27, 2017 06:21 PM
SAThompson
Feb 5, 2017 04:48 PM
batesd
Nov 30, 2016 09:47 PM
jonrjen
6.7L Power Stroke Diesel
Dec 27, 2015 09:38 AM
