4 wd not working. Please Help
Old Jan 21, 2005 | 05:23 PM
firebiz16's Avatar
firebiz16
Unhappy 4 wd not working. Please Help
I noticed today after I was stuck wheel deep in the mud my 4wd was not working. I had it in 4 lo and the front drive shaft would turn but my wheels would were not spinning. I turned the locking hubs both ways but it didnt make a difference. Any suggestions would be greatly appreciated.My truck is a 99 Dually 4wd
Thanks,
Chris
Old Jan 21, 2005 | 08:52 PM
kilroy99's Avatar
kilroy99
Usualy I would say that it was a vacume leak but, if your hubs didn't work manually then you may need new hubs. The problems I've had with my 99' have all been vacume problems. I first noticed it when my vents would shift up to the defrost position when I turned on my 4x4. First check the hoses and fitting at the wheel, then check your lines going up to the vacume canister. I used a hand help pump to make sure they held a vacume. I've also had to replace my vacume pump too. Hope this helps if you need more help let me know.
Old Jan 21, 2005 | 09:33 PM
Dieseldan7.3's Avatar
Dieseldan7.3
Automatic locking hubs are junk. If you find they are bad then replace them with some WARN hubs, not the OEM autos.
Old Jan 21, 2005 | 09:36 PM
Clemzeter's Avatar
Clemzeter
I'm kinda partial to my shift on the fly. Do you know if warn makes an upgraded auto hub?
Old Jan 21, 2005 | 10:29 PM
barebackjake's Avatar
barebackjake
nah the warns are good ole reliable manual only. when i know im in a situation where im gonna use 4x4 alot i just leave them locked and switch the tcase in and out. ive got a buddy in wyoming that has a 95 thats what he does seems like first snow puts the snow tires on and locks the hubs and leaves them that way all winter. its a little bit more wear and tear on the front axle parts cause now there actually moving now. but that truck has to have over 300k on it now and he hasnt had to do anything more than brakes and wheel bearings to it.
Old Jan 22, 2005 | 08:34 AM
firebiz16's Avatar
firebiz16
I have taken my hubs out before. I'm wondering if there is a way I could have put them back in wrong to where they wont lock? Or will they only go on when everything is lined up.
Old Jan 22, 2005 | 08:56 AM
barebackjake
with the auto it could possibly have had a oring or the diphram not seat. does your air blow out your defrost vents when you try to put it in 4x4? i know on the manual hubs they will only go in one way and if they dont work the inner cone is usually broken or the end of the axle shaft is boogered up.
Old Jan 22, 2005 | 01:25 PM
firebiz16's Avatar
firebiz16
mine are manual locking, The front driveshaft and u-joints turn but the wheels will not turn, I guess both locking hubs are bad. Any more suggestions before I spend the $200.00 to replace them?
Thanks,
Chris
1999 F-350 Superduty Dually 4wd
Old Jan 22, 2005 | 09:58 PM
RickyBR's Avatar
RickyBR
Does your dash light come on? When my 4x4 quit working the light quit working too. I have heard of the light working but no power up front.
Old Jan 22, 2005 | 11:36 PM
barebackjake
sounds like there broke fire. a set of warns will last lifetime of the truck
Old Jan 23, 2005 | 08:20 AM
lancer's Avatar
lancer
I agree with the warns!! I was never a fan of auto hubs! There to unreliable. We changed the auto hubs on my dads 2000 sd when he bought it last year. Just do as the other guys say, if you know your gonna need it lock them in and shift on the fly as usuall. I've had my hubs locked for over a month and just shift as i need it. No probs and i know i'm locked in!! Good luck!!
Old Jan 23, 2005 | 03:33 PM
firebiz16's Avatar
firebiz16
Thanks for all the help, I will purchase my warns from NAPA tomorrow.
