Black Soot
Old Jan 21, 2005 | 01:40 PM
csramsey640's Avatar
csramsey640
Black Soot
Is black soot in the tailpipe a bad thing or just an IDI thing? i know almost all diesel tailpipes have some, but how much is too much, and is that too much fuel?
Old Jan 21, 2005 | 09:31 PM
PLC7.3's Avatar
PLC7.3
The IDI does not have all the electronic things to adjust the fuel for every piston coming to TDC, so we have a little bit more soot at a lot less money...........
Old Jan 21, 2005 | 10:20 PM
bilder12's Avatar
bilder12
PLC has a good point but too much fuel is visible when you are working the engine and you cant see behind you due to black smoke. You should have a light haze from the tail pipe when working the engine.
Old Jan 23, 2005 | 11:10 AM
89ford73's Avatar
89ford73
he he, it's just getting good when you can't see behind you! and the soot in the pipe is a idi thing, if it comes out real shiny, like super black oil, then you should be concerned. that means the motor is using a LOT of oil. but you would notice that when you check the oil i would imagine. my truck has 330,000 miles and don't burn a drop. leaks like hell, but don't burn.
Old Jan 24, 2005 | 06:59 AM
csramsey640
ok great then i guess its normal
