EFI conversion & Flexplates
What I am doing is a 95 5.0 HO swap into my 73 Bronco with a C4.
My question is this. When reading through a bunch of different articles I ran across one that stated that the weights and or balancing on the flex plates was different and possibly the tooth count also. but for the life of me I can not find were it was at. Have any of you heard or know anything about it? Something like 27oz VS. 50oz of ballancing.
I am switching the computer, Mass Air, and distributor over to a 93 with the A9L computer. I will be using a RJM harness along with the HP and LP Carter pumps.
Also, I found someone with two T3 turbos they were going to use on a custom TT foxbody set up. I may grab those and build my old block for a twin turbo set up, has anyone heard or seen this done?
Any and all input is welcome
We are pleased you have chosen the best source for Fords!
See you on the boards.
Enjoy FTE
I haven't dealt with the 5.0 to C4 myself, but everything I have read says that the 89-93 Mustang AOD flexplate has the same bolt pattern as the Bronco C4. This seems to be what everyone is using.
Jason
