1966 - 1977 Early Broncos
EFI conversion & Flexplates
Old Jan 21, 2005 | 12:44 PM
Hallz's Avatar
Hallz
Question EFI conversion & Flexplates
I was wondering if any of you guys that have done a conversion have had or have heard of issues regarding different flex plates.
What I am doing is a 95 5.0 HO swap into my 73 Bronco with a C4.
My question is this. When reading through a bunch of different articles I ran across one that stated that the weights and or balancing on the flex plates was different and possibly the tooth count also. but for the life of me I can not find were it was at. Have any of you heard or know anything about it? Something like 27oz VS. 50oz of ballancing.
I am switching the computer, Mass Air, and distributor over to a 93 with the A9L computer. I will be using a RJM harness along with the HP and LP Carter pumps.
Also, I found someone with two T3 turbos they were going to use on a custom TT foxbody set up. I may grab those and build my old block for a twin turbo set up, has anyone heard or seen this done?
Any and all input is welcome
Old Jan 21, 2005 | 03:35 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE. Stick around someone will be by shortly...to answer your question.
We are pleased you have chosen the best source for Fords!
See you on the boards.
Enjoy FTE …..
Old Jan 22, 2005 | 08:06 AM
RCrawler's Avatar
RCrawler
Yes there is a balancing difference between the early 302 (28.8 oz) and the later model 5.0's (50 oz).
I haven't dealt with the 5.0 to C4 myself, but everything I have read says that the 89-93 Mustang AOD flexplate has the same bolt pattern as the Bronco C4. This seems to be what everyone is using.
Jason
Old Jan 23, 2005 | 02:27 AM
Hallz's Avatar
Hallz
Good deal thanks,
It sucks that I have to change the flex plate put at least I found out prior to starting it up.
