i replaced all of my fuel line, cleaned the fuel tank, checked for air leaks etc. EVERYWHERE, replaced fuel pump, coil changed and adjusted points, condensor cap rotor wires and plugs. i can still drive for about 10 minutes and the the truck gradually starts to crap out. i know for a fact it is not a fuel problem. the ignition wires dont looke to be in too good of condition. if the wires gegt warmed up, could they stop carrying the electricity if they are partially broken etc...?
adam
You may have a bad coil that get hot after a short while and starts to crap out.I would carry a spare coil and next time it happens , swap it out and see how it runs. When it dies, does it start right up or do you have to wait a period of time before it starts?Is the bowl on the fuel filter clean, no debris collecting there? Is the gas going thru it clean, not cloudy?
i repeat,it is not a fuel problem.... the bowl is clean as can be, fuel is always going thru the carb no problem... the coil has been replaced, getting plenty spark. when it dies if i fire it right back up it runs the same crappy way, but if it sits for 10 mins or so its good for another 5...
adam
If it's the 59 F100 in his profile it would be 12V. What ignition wires are you talking about? The under dash wiring to the switch or the wiring under the hood to/from coil and to distributor? Any of these can break down and leak voltage, but the most likely to cause your symptoms are the ones Barry and Ross have described.
If you replaced the condenser I'd try another one. They can be bad out of the box. They will cause symptoms like you have. Get one at NAPA - the one they sell seem to be the most reliable. Most of the NOS stuff is junk and some of the other outlets are peddling new junk.
Just one final thought on fuel system -- could the fuel cap be a non-vented type?
Did Ford use resistance wires to the coil on '59's? This is normal-looking wire but it actually serves the same purpose as a ballast resistor. Did these problems start when you put on the MSD coil?
the problems happened before i changed all the stuff, thats why i changed it. the cap is definately vented. i was referring to the wires to/from the coil looking bad. i have no doubt that the coil is good, its sending plenty of spark out.... this is really bugging me. i had parked it for a while because i was getting so frustrated and its doing the same thing no matter what i change... lookin like its getting parked again
adam
You said it wasn't a fuel problem, but it sounds a lot like vaporlock. Are any fuel lines close to headers or other heat source? Does the carb inlet have a sintered filter in it?
Ignition usually works or it doesn't.
Next time it quits, I'd pull off the float bowl cover and see if the bowl is full or not at that moment.
fue lines travel on the opposite side as the intake and exhaust do (223 inline 6) ive pulled the bowl off right after it did it and the bowl was full, all filters free of debris.
My "vapor lock" problems, as I diagnosed them one hot summer day in the desert, was debunked by Doc Jacobs at my daughter's house. He showed me how my ballast resistor was over heated and failed to run the proper 'electrics' through the system to produce enough spark. He got the thing cranked right up, gave me a copy of his book and off I went.
Even now, my ballast resistor will smoke... it evidently resists the change to a new manifold with multiple carbs. With my Jacobs system installed, however, I have no more starting problems. Good luck with it. himmelberg
Dude.. I have a 223 Inline 6 and had the same problem.. it ended up being a bad carb.. No joke.. I rebuilt it 5 times with 5 new kits.. I had a acid boiled out and it still was bad.. ended up getting a new one and now it runs great.. I had replace all the plugs, wires, cap, rotor, and coil.. It a head ache.. but get a diffrent carb and U will see the diffrence... Mycarb was a Model 1904 Holley.. I still have the old one.. But it would be cheaper to just up grade to this http://www.stoveboltengineco.com/aca...p?productid=95 with this http://www.stoveboltengineco.com/aca...p?productid=91 and its cheaper then a new holley 1bbl 1904
Could be a stupid suggestion, but here goes... What type of air cleaner and whats the weather like? I have had carb iceing problems that act a bit like this from time to time.
adam
I had a set of spark plug wires start giving trouble a few months back. I didn't want to believe it because they were only a year old. I replaced them as a last resort and it runs great now.
