Electrical problem
Old Aug 12, 2002 | 09:21 PM
rfgree's Avatar
rfgree
Electrical problem
My friend has a 1985 F-150 which he has been working on for several months to no avail. He has a 302 automatic. I beleive it is throttle body injection. His problem is that when he first starts his motor it may run five minutes or an hour. Sometimes he will go to the store, cut the engine, come out of the store and it may not start. Wait an hour or so and it will start right up. It may stop after only a block or so and start right up again and then again maybe not. The only thing consistant about it is that it always starts up after it has set awhile. He has used starting fluid in the breather and that doesn't help. Tapped on wires, pulled and tucked for endless minutes. Replaced fuel pumps, filters etc. Anyone had this problem before?
Old Aug 12, 2002 | 09:29 PM
Franklin2's Avatar
Franklin2
Electrical problem
When it quits, you will have to determine if it's a spark (ignition) problem or a fuel problem.
Old Aug 12, 2002 | 09:35 PM
rfgree's Avatar
rfgree
Electrical problem
It has been determined that it is is an electrical problem because the starting fluid does not help.
Old Aug 17, 2002 | 04:35 PM
wille3r's Avatar
wille3r
Electrical problem
It could be the "brain". My mama had a Ranchero that did that and it was the brain. Hope your buddy gets it fixed! Electrical probs can deal misery.
Old Aug 19, 2002 | 11:40 AM
brown 4x4's Avatar
brown 4x4
Electrical problem
I'm guessing the TFI module on the distributor needs replaced. Because of its location, it acts like a heat sink and is a common failure. Common symptoms are hot stalling/no start, then when it cools down it will allow the truck to start again.
[font color="green"]1995 F-150 Supercab XLT 4x4 302 M5OD 8' bed [/font]31x10.50's
[font color="green"]1986 F-150 4x4 300 I6 NP435 [/font]Warn hubs, DeeZee bed caps, '96 XLT bench seat, new paint job
Old Aug 19, 2002 | 05:49 PM
cwyse's Avatar
cwyse
Electrical problem
The TFI module is known to cause the problem you describe !
As well as a bad connection.My85 EB had the same symtoms.I replaced the tfi still had some problems,turned out the pickup in the distibuter was bad.
Old Aug 19, 2002 | 08:34 PM
Jimbare's Avatar
Jimbare
all alone in the world
Electrical problem
Bar B Q
Feb 27, 2015 06:36 PM
Bar B Q
Feb 22, 2015 06:34 PM
ktsdc05
Jul 3, 2012 07:57 AM
nalts
Sep 18, 2010 07:15 AM
ditch witch
Feb 4, 2006 07:44 AM
