4 wires?
Old Jan 21, 2005 | 09:38 AM
fito1411's Avatar
fito1411
4 wires?
ok , i was looking under the hood and i found 4 wires (red,white, blue, and black)that are taped together. They are to the right of the brake fluid reservoir.What are they for? By the way 2005 F250 crew cab 4x4. fx4 lariat 600 miles. Thanks in advance.
Old Jan 21, 2005 | 09:47 AM
micguyver's Avatar
micguyver
They are a direct feed to under the dash behind the fuse panel. They can be used for accessories that you may normally fish wires through the firewall for. I've already used two of them to feed driving and fog lamps.
Old Jan 21, 2005 | 09:51 AM
fito1411's Avatar
fito1411
do they go to the upfitter switches?
Old Jan 21, 2005 | 09:53 AM
micguyver's Avatar
micguyver
No, they are free at each end. You can attach an upfitter switch wire feed to it though, which is what I did.
Old Jan 21, 2005 | 09:57 AM
fito1411's Avatar
fito1411
thanks for the help!
Old Jan 21, 2005 | 10:11 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Good info on the upfitters
https://www.fleet.ford.com/truckbbas/non-html/Q117.pdf
Old Jan 21, 2005 | 12:35 PM
pdbd's Avatar
pdbd
Great I'll use them for my alarm system
