Hey, I have a 1998 F-150, and its having trouble starting the past couple of cold days up here in New Hampshire. At first I thought that it was the starter, but the truck would go through spurts where it would turn over for a split second. So the starter problem is ruled out.
Another issue that came to mind in the cold air intake that I put on a couple months ago. Could the truck be getting too much air trying to start it in the morning? Could the air be too cold/thin for the motor to run? Once the temp. warmed up a little it started up. Oh, and also, when we start it in the cold, to keep it running we have to lay on the gas a little bit so the RPM's stay up, or else it boggs out.
Any advise is awsome and greatly appreciated.
Thanks you guys,
I know that the starter is on its way out, but that is not the problem in this scenario. I have come to the conclusion that it's getting too much air when it's starting, and not enough gas...the truck is trying to start too lean. cause when I start it i have to play with the gas pedal a little bit. my father and i were wondering if there is a sensor that should have been changed. Like a high idle sensor, or someting like that.
