Throttle Hangup
Old Aug 25, 2002 | 04:24 PM
bigin302's Avatar
bigin302
Throttle Hangup
Well, my 302 is running fine after the swap from the 300. The throttle is hanging up at around 1500 RPM though. I don't know whats causing it. Any suggestions?
Old Aug 25, 2002 | 05:07 PM
paveslave's Avatar
paveslave
Throttle Hangup
Do you have a throttle return spring? Look on top the throttle body where your accelerator cable hooks up. If there's no spring or the one that's there isn't strong enough, get one. My truck did that when i first bought it and I noticed it didn't have a spring at all. Quick run up to the parts store and I was running good in no time. I hope that's all it is in your case too, good luck..
-Ry
-If it aint broke, fix it till it is...
-Stop telling God how big your problems are, instead
tell your problems how big your God is...
1985 F-150 302 4X4
Dana 44 TTB / 9 inch
4.56:1 Front/True-Trac
4.56:1 Rear/Detroit Locker
C-6 Tranny, NP208 Transfer
6 inch Skyjacker Class II lift
35 X 12.50 BFGoods AT's
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=6696&.jpg https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=6663&.jpg
