1978 - 1996 Big Bronco
Am I getting old ....
Old Jan 20, 2005 | 07:44 AM
Will_01_GT's Avatar
Will_01_GT
Or do I just forget , I couldn'tr disengage my 96 EB from 4x4 while it was in drive, I was able disengage in Neutral, Don't we have "on the fly" 4x4 meaning it should be engagable while driving
Old Jan 20, 2005 | 11:19 AM
greystreak92's Avatar
greystreak92
You're just getting old....(hehehehe) But then so am I because my recollection says you are right and the T-case should disengage on the fly. However automatic hubs will usually require that you back up about 10-15 feet before they will disengage...well until they just fail like most autos do.
Old Jan 20, 2005 | 01:23 PM
irondragon79's Avatar
irondragon79
Yeah, if I read my users manual correctly, you can hit the button on the dash and "disengage" the transfer case, but your auto hubs will still be locked so everything up front is still spinning. You need to do that whole "finding a spot you can back up 30 feet" routine to fully disengage.
As far as engaging, I believe if everything on your bronco is in good working order you can shift into 4H as long as your under 45mph, for 4L you need to be stopped and in neutral.
Old Jan 20, 2005 | 07:07 PM
aurgathor's Avatar
aurgathor
If you got a big enough strain (driveline windup), the T-case won't shift back to 2WD until the tension is relieved.
Old Jan 20, 2005 | 08:14 PM
desertdave35's Avatar
desertdave35
I got a 91 silver annivesary that does the exact same thing. Drives me nuts!! I'm half tempted to convert to manual hubs.
Old Jan 21, 2005 | 06:44 AM
Will_01_GT's Avatar
Will_01_GT
Ya, I figure it was normal, I also have manual Warns. Drives me nuts I'm getting old and forget snow strom to snow strom, Thank god for FTE .
To all in the North East .... Happy N'r Easter this weekend !!!!!
st8yd
Sep 17, 2012 06:34 PM
mallardchaser
Mar 23, 2011 10:35 AM
DieselJr
Jan 28, 2010 12:14 PM
index_case
Bronco II
Feb 13, 2004 02:11 PM
verosey
Sep 6, 2003 01:36 PM
