That is an interesting solution to the bearing problem. I am guessing from the picture that is a standard 3/4" ball bearing and three screws to center and retain it. If it was me I might fill around it with epoxy (JB weld). I wouldn't worry about any rattles.
If you do a search here you should be able to find multiple threads with sources for the OEM bearing.
Dennis carpenter and auto krafters carry them, for $10-$15 if I remember correctly. The oem ones seem to be strong enough and last a while - unless the cab mounts are shot. That puts a lot of stress on the bearing.
Dennis-Carpenter.com lists this lower bushing with plastic flange for $6. The site lists it as a 73-77 part, but their info link says it works up to '79 2wd with fixed column.
Part # D9TZ-3C773-B
Marty
6 bucks is worth a shot just to find out if it works
most of the earlier lower parts won't work with the late columns
there were black and white bearings.
yeah that pic does look like there is a lip at the end of the column that is wierd.
late-77 to 79 column don't have that lip. I think that lip was part of the conversion.
maybe shortening the tube a little.
the really annoying problem is that most of the late columns have the rag-joint flange welded the the steering shaft, so you have to dis-assemble the column to replace the lower bearing (you lucked out if you have a late column with a bolt-on flange). that shaft is splined, which makes me think its an earlier column or a late77-79 4x4 column.
if you look real close the rectangular cut-out for the plastic bearing locking tab looks like it is about 1/2" from the edge where the fold starts. all the ones I've ever seen have that cutout at about that distance in with no fold made so that folded area might be piece welded on
I found this one with a simple search for "+bearing +steering" that took about 2 minutes to find looking thru threads. Many others are contained in that search. -Simple...
simple yes, and wrong
every link in that thread came up with the wrong bearing,
have you actually seen the late 70's one piece plastic lower bearing torque1st?
I know people love to jump on the do-a-search bandwagon but
they should know what they are talking about before doing it.
