Sponsored by: Real Truck
4 lo no go
Old Jan 19, 2005 | 02:55 PM
stealth1's Avatar
stealth1
4 lo no go
My 02 will shift into 4hi without a hitch but it will not engage into 4lo at all. I have tried everything. The hubs engage in 4hi and works great. Could the switch be bad or is something else the culprit?
Old Jan 19, 2005 | 03:29 PM
Pirate16's Avatar
Pirate16
Thumbs up
are you following the procedure exactly, there was a post a while ago, make sure you are on the brakes when engaging, the 4lo is connected to the pedal won't engage without the brakes on.
Old Jan 19, 2005 | 03:31 PM
stealth1's Avatar
stealth1
Thanks for the reply. I tried brake on, outta gear, in gear, everything possible that I could think of..
Old Jan 19, 2005 | 07:11 PM
99f350sd's Avatar
99f350sd
Has to be in neutral foot on the brake as far as I know. If it won't go after that it must be the sw or the motor thatcontrols the transfer case.
Old Jan 19, 2005 | 10:05 PM
SMiller's Avatar
SMiller
Foot does not have to be on brake, truck just has to be in neutral and stopped. I put mine in 4-low all the time, just put it in neutral and pull it on back, do have to tug on it a little to get it all the way back to 4-low...
Old Jan 20, 2005 | 12:16 AM
99f350sd's Avatar
99f350sd
Esof...........................
Old Jan 20, 2005 | 01:04 AM
SMiller's Avatar
SMiller
I'm slipping, duh! It would be nice if he stated that though...
Old Jan 20, 2005 | 06:54 AM
99f350sd's Avatar
99f350sd
He almost did!!
"The hubs engage in 4hi and works great. Could the switch be bad or is something else the culprit?"
I think you slipped
Dick
Old Jan 20, 2005 | 07:09 AM
Brad99SD's Avatar
Brad99SD
I had the contacts in my switch get dirty once, it would go in to 4lo and back to 4hi then in again and ect...... about every second or so. I popped the switch out and took it apart and cleaned the contacts and it works great now. Not saying that is your issue but worth a try. There is also 2 30amp relays that control the 4wd up by the brake master cylinter under a black cover. One is for 4hi and one is for 4lo, I pulled mine out and cleaned the 5 spades(pins) with my pocket knife. While I was doing all of this I went ahead and pulled my 2 plugs off of my T-case motor and sprayed some electronics cleaner in them, wouldn't hurt to clean those also. good luck
Also do a search on ESOF in this forum, I can't remember but I think it was big orn that had a very detailed post about ESOF with even the relay #'s.
Old Jan 20, 2005 | 10:30 AM
stealth1's Avatar
stealth1
I will do that right now. Thanks for the fuse info...
Old Jan 20, 2005 | 10:53 AM
Brad99SD's Avatar
Brad99SD
They sell those relays at your local autoparts stores,(I believe they are just plain old 30A relays) I don't know how well you are versed with electronics but you could test them(kind of a pain) or just by a couple new ones.
Old Jan 20, 2005 | 02:47 PM
stealth1's Avatar
stealth1
Thanks a million... I cleaned the fuses and like magic it switched into 4lo perfect everytime!!! Saved me a big headache and probably a few $$$ at the repair shop..
Old Jan 20, 2005 | 08:24 PM
lugnut's Avatar
lugnut
Also, don't forget that with a manual trans. you have to have the clutch pushed down in order to go into 4-Lo. I'm just glad that I read the manual before I went and complained to the dealer!
mike
Old Jan 25, 2005 | 12:04 PM
Brad99SD's Avatar
Brad99SD
Glad to hear that it is working for you now stealth. Maybe the 4lo relay just had a bad connection. You don't have too but I also wouldn't hesitate to pop off you plugs on your Transfer case and spray some cleaner if you can locate them. They are kind of a pain if you have the off road package because of the skid plate, but not horrible. I had minimal dirt in mine after 100,000 miles because they have them sealed pretty good but I thought it wouldn't hurt to clean them anyway(too much time on my hands I guess, he he). My switch must have had a bit too much contact grease or something, just wiped the contacts a bit and away we went.
